How-To For Front Lower Control Arm Bushings?
Wwaterman
Car: 1996 Pathfinder
Can anyone point me in the right direction?
Wwaterman
Can I just unbolt the inner bushing areas (2) and unbolt the 3 triangular placed bolts on the lower bolt joint and take the whole control arm off?
AlanAZ
Car: 2003 Infiniti QX4 RWD
First place to research a task is the FSM (Factory Service Manual) that's available for download in the 'General Information and FAQ' sticky thread above. It will have basic instructions, requisite instructions, and torque specs for reassembly. I print those pages.
I then use the search engine above and read through all threads and posts related to the task, cutting and pasting relevant info into a word doc and print. You'll be surprised at how often one little tidbit can save you half an hour of frustration.
Replacing the front pressed-in bushing with split-design poly will be the same as replacing rear bushings with split-design poly, research how that is best done.
04Chinook
Wwaterman wrote:Can I just unbolt the inner bushing areas (2) and unbolt the 3 triangular placed bolts on the lower bolt joint and take the whole control arm off?
Yes. This is how I took mine off. Very easy. Just remember to torque everything with the full weight of the vehicle on the ground, and of course get a wheel alignment.
