Those look like the Radio Shack relays posted on the first post, and similar to the ones I bought from RS as well. Make sure the pins will actually fit in your car, though! They didn't for my 2001 and I had to modify one factory relay (well, just cut a hole in the blue plastic housing to attach an alligator clip, really) to do this mod.sc2nr wrote:Ok, Found these... http://cgi.ebay.ca/12-VOLT-4-PIN-SPDT-A ... 2309a6f5f7
Will those ones work?
The schematic shows for pins and it sorta resembles the configuration from the first post on this thread so, I think I will order them tomorrow, anyone else care to weigh in?Those look like the Radio Shack relays posted on the first post, and similar to the ones I bought from RS as well. Make sure the pins will actually fit in your car, though! They didn't for my 2001 and I had to modify one factory relay (well, just cut a hole in the blue plastic housing to attach an alligator clip, really) to do this mod.
donald wrote:Just did the mod to make my fog lights run seaparately... but in a completely different fashion.
The method I used was to cut directly into the harness leading up to the fog light relay and re-wired it to my parking lights power-line.
So instead of using relays and the A/C relay to turn on the fogs, I'm able to turn on the fogs with the ignition at "OFF" or "ON", since the fog light relay now triggers off of the parking lights.
Now, the way I did it does pose a little more hassle in that it's not "automated" in anyway. You have to switch your lights to "parking lights - ON" to use your fog lights.
I'll try to post up pictures of what I did in a few days.
I'm one of those spur-of-the-moment mod'ers that did this late at night and was in a rush to go to bed - so neglected todocument anything. But I'll try to make up for that and show the aftermath.
Hey there Nocturnal - go to the above threaddonald wrote:ok - i didn't wanna fart all over this thread, so I created another one that has a different re-wire method. Found here: post5968309.html#p5968309
good luck!
