Bigger Picture:
https://i.imgur.com/gqI5Tsf.jpg
These capacitors seem to blow (some look like decoupling capacitors), which causes the signal to get all f*** up. I tested the caps with an ohmeter and it had really weird resistance values on some of them. Notably, if there's a cap that's discolored, it could be replaced or pulled with a high chance of fixing the board. I don't have a capacitance meter, but if you wanted to find the capacitance you'd have to pull the cap and figure that out. I would have done this but I don't have a cap meter, and had a spare donor board to pull caps off of, to make it work.
I'd imagine the actual part that goes bad is probably easy to afford; they can't be any more than a few cents each.
These clusters do not simply 'go bad' over time, and it's convenient that these surface mount caps are on this side of the PCB, which makes it easy to access as opposed to the other side. I'm sure the S14 might have similar problems in the future, because these things are getting older over the years.
Don't throw out dead clusters; all this s*** is fixable and it's SAD seeing them go for 100-250 freedom dollars on ebay.
Here's a video of me bench testing the thing after fixing it. I don't expect everyone to have the tools and whatnot lying around to do/test this, but you can pull surface mount caps off a board using a butane torch with a hot air attachment.
