The problem is , I think I did scratch the paint.....the white mark do not come off when i rub them with a wet finger. I will try your other suggestions. Hey, do you think car washed with the spinning brushes are bad???? it is kinda too cold to be washing myself.philipa_240sx wrote:Firstly, simply 'wiping' is not enough. You need soap and water to flush away the dirt otherwise you'll end up scratching the paint.
I would try washing the car properly first.
If that doesn't fix it, then a clay bar + detail spray should be able to lift off the dirt. Follow it up with a good wax/sealant and you should be good.
I like using Meguiars products, but there are other good ones out there. Check out our detailing forums:
detailing-forum.html
Um.... yes. Not a big fan of automatic car washes.rayjgold wrote:Hey, do you think car washed with the spinning brushes are bad???? it is kinda too cold to be washing myself.
Thanks!
Nick 568 wrote:Or take it to a touchless laser wash. Not as good as washing by hand or having it professionally detailed, but far far less damaging than going through a car wash in which the spinning brushes contact your car.
