how to find a vacum leak
sloweighty
Car: sileighty
ok i think i have a vacuum leak and i need to know how i can find that leak the leak. I heard you can spray some stuff and if the motor acts weird then the leak is near the area where you spray the stuff with. (I really don't know I just need some help) If anyone can help please help.
slyedog240sx
Car: 93 240sx se coupe, 05 grand cherokee HEMI Power
sloweighty wrote: ok i think i have a vacuum leak and i need to know how i can find that leak the leak. I heard you can spray some stuff
brake cleaner.
sloweighty wrote: and if the motor acts weird then the leak is near the area where you spray the stuff with.
Engines idle will increase.
sloweighty
Car: sileighty
so do you think it is ok to spy brake cleaner on the vacuum lines and my car is already having a problem with high idle because the rpm will be above 1500rpm and when i give a little tap on the gas the rpm will drop down for just a second and then it will jump right up and then i would get this black smoke that would have a strong smell of gasoline from my exhaust. My check engine light is on too and i got it checked out and the guy who diagnose the problem said it is because of the EGR and i have a brand new EGR so could it be because of he BPT valve or what? PLEASE HELP?
slyedog240sx
the trick with the brake cleaner is mainly for intake leaks. Use a vaccum gauge tester and get the specs from the fsm if you think that is the problem
safin
did you personally install the EGR? you should check that again, before you even start spraying anything
i would reccomend you use carb cleaner, instead of brake cleaner they both would do the trick but it seems like brake cleaner is not that plastic friendly. it laeves a different kind of residue
good luck!
sloweighty
Car: sileighty
good luck!
yea i replace the EGR when i had the motor out and i replace all of the vacuum lines and i also replace the gasket for the EGR but i was thinking, could it be one of the little valves that i see that is connected with the vacuum lines. I have a ka24e and i have alot of vacuum lines and i what these three funny looking valves that are connected to the vacuum lines, two are in the back of the motor and one is on the side next to the header. So if anyone can help please help
sloweighty
Car: sileighty
bump
sloweighty
Car: sileighty
bump
sloweighty
Car: sileighty
sloweighty wrote:bump
bump
