hnm3355 »
https://forums.nicoclub.com/hnm3355-u222114.html
Tue Jul 02, 2013 5:24 pm
i have a 1985 2.4 pickup and it recently failed emissions, first thing i did was check timing with a light, found it at 20 over tdc when warm in drive. so i retarded it back down to a 5* over tdc like the book said, imidiattly noticed the smell of gas dissapeared. and ran a bit slower. i went ahead and replaced the following thinking it would solve the problem, CAT,plugs wires , dizzy cap and rotor, air filter as well as the muffler. after replacing all these the CO reading was reading 20 grams higher than the first time it tested, 160 over 40allowed , alot. i did managed to improve the HC levels from 6.0 over 4 to 4.7 over 4 almost there to pass on the HC.
Big question is what else is needed i have spent a little over 150.00$ on all new parts and need help to see if any one has ideas or knows what causes the high lvls of C.O.
note one thing i think needs replacing is the dizzy's vacuum advance the year prior to failing the truck passed perfectly and all of a sudden it failed and was advanced 20 degreees, any one else think its bad. plz if any one can help me out, im in dire need of assistance. im past my 30 day permit that i al allowed and time is running out.
