How to extract window regulator?
OneTimePoster
Q45. Door panel is off, all the regulator bolts (3) and track bolts (4) are off. What do I do now? How to I get the window out of the regulator so I can get it out, and then when I put the new one in vice versa? Thanks.
Q451990
Assuming you're talking about the front... I had to remove the speaker assembly to get it out of there. The regulator bolts on to a plastic retainer that's glued to the bottom of the window.
Heath
OneTimePoster
I got those bolts, and I have the speaker out. Do I need to remove the 3 screws to ?the motor??? -- there seems to be a black electrical wire/conduit that its tugging on.
Q451990
Yes, the motor assembly must be removed from the regulator.
Heath
