That is a good idea that Greaser had a few years ago. Keeps fresh air circulating through the crankcase. The benefit is to reduce windage and increase oil life.
I have a pipe fitting on the oil separator that has a line that goes to a catch can, then to the turbo inlet with a slash cut through a PCV in a rubber grommet. This hopefully helps draw some of the crankcase pressure via the bernoulli effect, thus increasing cylinder sealing and reducing windage.I got this kit from
http://www.theoldone.com.
By dumping the oil separator line to the ground, you are not achieving any vacuum, however you are also not recirculating any blow-by into the intake. It's all a give and take that may warrant some trial and error.
I have chosen to recirculate. Also, my KA-T passed emissions better than without turbo.
On a low boost motor I would probably recirculate, however high boost applications may generate so much blow-by that recirculating the crankcase fumes could cause detonation/loss of power.
