How to drop cross memeber?
wellcraft
Car: Z32 1990
I need to rebuild my rack and pinion and was able to find a diy for it but cant find a diy on how top drop cross member on my 1990 na.
Can someone point me out to a diy that explain on how to do this?
Ill be replacing oil pan gasket too.
Thanks.
300ZXttZMAN
wellcraft wrote:I need to rebuild my rack and pinion and was able to find a diy for it but cant find a diy on how top drop cross member on my 1990 na.
Thanks.
I just did this also. I pulled my trans first then I removed the plenum and bought a jig from harbor freight and it worked great, it held my engine up for a little over a month. I suggest you wrap the chain around the exhaust manifolds if you are still using the cast iron OEM manifolds.
Then after that I just unbolted the subframe as your normally would and left the coilovers attached to the subframe.
Its pretty straight forward, just kinda labor intensive.
Good luck!
z32loverboy
Car: 1990 300zx CRP N/A 5 Speed (wreaked, now a shell) SOLD
1993 Slicktop CRP N/A 5 Speed w/ '90 built N/A motor and interior
1958 Ford f-100 straight-body (Grandaddies truck, resto-project)
Yeah, I used a engine crane from harbor freight to support the motor and un-did the motor mounts and pulled all the suspension. Though I did it the long way when I pulled each individual suspension piece.
