Thats what I do with my Escape Hybrid which also has CVT and I am getting 33mpg combined (right in the suggested range for the escape). The times when my mpg rating suffers is when I am running late or its just to freaking hot outside(see my thread about AC questions).philmcneal wrote:here's how I'd do if if I owned a versa.
Accelerate using max efficent torque curve (ususally 2000 rpms) when getting up to crusing speed. Try to cruise in the speed you want in the lowest rpms as possible. One can do this by when you have reached the speed you want to cruise at, let off the gas pedal and then lightly reapply so that you can still maintain the same speed. The less throttle, the less air into the cylinders and air needs fuel to run.
In city driving, I try to coast as much as possble. If travelling under 40 mph one can let off the accelerator pedal and the car's revs will drop, acting as if it is in neutral. If you had a instantenous fuel economy gauge like a scangauge, that number would be rediciously high since your travelling by using the least amount of energy possible (keeping enough gas for the engine so it does not stall).I try to use the most of my coasting (small amount of fuel to coast a huge amount of distance), so that by the time I hit the red light, my speed is dropped to 10 to 15 mph instead of slamming on the brakes at the last minute at 30 mph. Being the last one to be at the light instead of the first will yield surprisigly good results... like the light turning green again and you have some momentum from your previous coast! So that the CVT does not have to lower the gear, if you can acclerate in higher gear, by means do so to avoid friction losses (the faster the rotation, the higher chance of that energy being lost to friction).
That's it for now
Interesting read, and for the most part I do a lot of what was in that article(I have the nav system which gives instant fuel economy as well as charting the last 15 minutes). My reasons for trading the Hybrid in are also mentioned in the article tho. It mentions all the great numbers come with AC off which is next to impossible for me to do in Phoenix more than half the year (winter is where the Hybrid is perfect here). And it mentions trying to stay off the highways (not an easy thing to do as well, altho in city highway, it does pretty good). We like to do weekend trips where we are driving thru the mountains (6-8% grade) and can watch the MPG average drop 100 mile drive (get some of it back on the down trip letting gravity work in our favor).philmcneal wrote:before you trade in that hybrid take a look at this http://www.cleanmpg.com/forums...t=350
since this is a versa forum i'll add in some versa comment:
the only advantage i see over the CVT vs 6spd is that when starting from a standstill, you burn less gas getting to crusing speed as opposed to the 6spd (maybe who knows?) my impression of the CVT so far that it isn't as energy efficent as a 6spd but then again CVT users maybe driving a bit too agressively?
with the 6spd i'd would purposely shift to a higher gear and cruise around 1300 rpms (the least amount of rpms before lugging hits) but would a cvt at the same rpms yield the same fuel economy? or cvt is at a disadvantage due to friction losses? so maybe 1300 rpms in 6th gear would be equal to 1600 rpms for the cvt?
damn hard to say without no data and with people without scangauges.
Not really. CVT's have been used in forklifts for decades... something like 50 years or so. Subaru used a CVT in a passenger car (4WD, no less) in the late 80's, but as far as mass-marketing, the car industry waited until now to develop and produce. Honda and Saturn were the first in the latest round. And now you even have Dodge playing around with them.elwesso wrote:Ive done a lot of research on CVT's, and the technology is very new at this point, so dont give up on them yet...
How many years we are talking about. If it is about 8-10 years i ll be definitely buying a new car by that time. I don't want a keep a car for more than it is supposed to live. And with new technologies evolving every year (god, every month), i ll be looking elsewhere by the time my versa is 8-10 years old, for sure!Ever Victorious wrote:
I'm still waiting and seeing. It's not the concept of the CVT I don't like... in fact, I think it's really something spectacular. It's that I want to make sure the manufacturers don't repeat Subaru's little error in the 80's by making a transmission that lasts only as long as a timing belt.
As I had mentioned in another post, the CVT on the Subaru Justy had an average life expectancy of only 70,000-80,000 miles. If you're an "average" driver (i.e. 15k miles/yr), this will only get you to 6 years. And in the case of the Subaru Justy, when the CVT failed, it was less expensive to pay a mechanic to refit the car with a manual than it was to repair/replace the CVT.ilusha55 wrote:
