JdrifterCA wrote:wuts normal compression for KA? i redid the test again with the engine fully warmed up and it reads 160/150/150/160. How much oil to add?
i'm not sure if you have a ka or sr, but for what i learn on sr20 is that if your have all 150 for all cylinder you have a normal motor actually is good. but if you have like you said 160 150 150 160 is not good or maybe is good for Ka motor. i have all 150's for sr20. just to let you know. if you have sign of oil on the tread of the spark plug meaning you might have a bad piston rings or spark plug o-ring seal. as long there is not a lot of oil on the plugs. if it is..is BAD
