how to disable the head lamp
marcoashura
I want to know how to disable the headlamp when the e-brake down?
ILoveMyRHS13
Car: 1990 Nissan 240sx (Hatch)
kouki munster
Car: 97 base 240
I think that he is trying to disable the day time running lamps.
Op, your best bet is to find a fsm for your car and look through the wiring sections to see if there is any thing you can do to disable them. (probably cut a wire or unplug something)
Chris28
Car: 92 s13 KA-T
Take out the fuse.
zenki-S13
Car: 1990 Nissan 240sx S13
ILoveMyRHS13 wrote:
King Ranzo
Car: 15 Ford Focus ST
Oh look a free post.
laxands13
Car: 93 240sx Hatchback - Sold and missed
80 280zx - sold
83 Honda Civic Wagon - Current DD, soon to be CA16 powered
Hooked on 240
Da fu.ck is a free post?
laxands13
80 280zx - sold
means you can put anything you want because the thread is stupid and prolly gonna get locked
Xdisaster240sX
Car: S13 Hatch, R32 GTS4
kouki munster wrote:I think that he is trying to disable the day time running lamps.
S13s dont have day time running lamps.
Op, you need to be more specific on what you mean. Your ebrake has nothing to do with your headlights.
Well...What year do you have? This info will also help
kouki munster
Car: 97 base 240
Xdisaster240sX wrote:S13s dont have day time running lamps.
Canadian s13's do, but that is beside the point, using my brain I was able to come to the conclusion that he most likely has a s14 as the drl's in the s13 are separate from the headlights, and he said that the headlights come on when he disengages the e-brake. In the vast majority of cars with day time running lamps, when you disengage the e-brake the drl's turn on.
corn322
Car: 1993 240sx
The switch the e-brake lever actuates to make the "brake" light in the dash come on might also activate the DRLs. You could maybe leave the e-brake on the 1st click, so it's hitting the switch but you won't be dragging your rear brakes. But then the "brake" light will be all in you face.
kc240guy
Car: gold s13 and a maxima
at the first click though it still might clamp a little on the brakes.
numbnuts240
1974 Datsun Fairlady-Z 250GT
2011 Ford Focus
2010 Mazda 3
going to have to do some wiring modifications if you want to disable the dtrl's.
barefoot mat
Car: twin cam s13 fastback
n b fo da loc
marcoashura
im sorry about my english~because my english is not good.
I mean
when i start the engine all head light is off, but if I put down the ebrake, at this time the little light will turn on.
however i put up the ebrake the light still on~
and i turn off the engine~then try to start the engine the light will be off (ebrake up)
so~the light will always on when the first time i put donw the ebrake
i'll post the video later hope someone can give some suggestion
Modified by marcoashura at 5:07 AM 2/20/2010
marcoashura
same as the image the headlight will on when the ebrake down, thx
krash
pretty sure those are running lights. Don't mess with them. They lower your insurance and don't effect anything.
whyteboi
Car: 1993 Nissan 240sx
whats wrong with having your daytime lights on anyway, doesnt hurt anything and makes you easier to see on foggy mornings or any other low visability time
marcoashura
i don't like the functon "daytime light?" in the night
i like open AC listen music and think something in the public park and the fuction will not good when i do that, in the day its okay but not night
SirSilvia
Car: Sold both my babies
barefoot mat wrote:n b fo da loc
bahahah
but back to topic, i was not aware this did that on koukis
marcoashura wrote:
same as the image the headlight will on when the ebrake down, thx[/QUOTE
