ukrkoz »
https://forums.nicoclub.com/ukrkoz-u214559.html
Sun Apr 13, 2025 8:57 am
Didn't have chance to get to the sensor yet, maybe in few hours but here's what I found:
C1805 code, Height control sensor down.
It showed yesterday, I cleared them all, took her for a drive this am (rear was still 3/4 inch up vs front, so OEM bags hold) - and that code returned.
I know, it's very simplistic, but the way I read it, it does say, that sensor reads CA position as lowered and no need to turn on comp, and then OEM bags slowly loose air, as they should.
Also, I did solenoid check, and I can hear it click, so no issue there.
I'm more and more leaning towards simply adjusting the arm on sensor to make it believe that suspension is slightly sagged. Error and trial, of course.
Does anyone know if there's pressure sensor in the bags, cutting it off preventing overinflation? Don't want to blow bags or burn comp, if I adjust it too much.
Oh, and I do have hydraulics. If it makes difference. Oil change is $852 plus tax dealer only, hence all this goofy stuff with Firestone bags.
