How to delete Egr with engine in car
DanDrath
Car: 1990 Nissan 300ZX 2+2 TT
I have searched and havent been able to findany wtire ups on how to do this. Can anyone help me out explaining a little or help find one. Yes i know its gunna be really hard to do and i am better off pulling th engine but i dont have the time to do that to my daily driver
Please help Thanks NICO!!
KevinZtwin
Car: 1990 300zx Twin Turbo
You will need to pull the transmission in order to remove the EGR and plug the DS exhaust manifold. You'll probably need a die grinder to cut the EGR tube connected to the exhaust manifold as there are some water lines to get around. While the transmission is out you can install downpipes also and upgrade your clutch/flywheel and clutch pivot ball.
xclusivez32
Car: 1990 300zx 2 seater limo
tt engine build
2004 gmc serria
i deleted mine while the engine was still in the car and it was not very hard. i used the write up that they made with the engine out, its the same except your working in the engine bay. why are you going to delete it? if it works i wouldnt mess with it there isnt a gain except a few less wires and pipes in there.
DanDrath
my egr code is coming up. And i think its probably clogged.
DanDrath
u use the robo delete write up?
Zwicked
Car: 1990 300 ZX tt, 1990 240SX
You should check the EGR solenoid connector first.It may just be corroded and not making contact as that's the only way (or wiring or the solenoid failed) that the ECU knows there is a problem with it.
It's not only difficult because of the trans in the way to get to the exhaust feed tube, but the tubes under the plenum each side near the front are also a PITA with the plenum in place as they run underneath it and around the rear corners to the EGR itself.
DanDrath
I was planning to probably remove the plennum if i do the delete but thanks i will check the connector to see if thats the problem. Got a mess of wires to search through lol
worldisgrand
Car: 1990 300ZX TT
This is what I did with my newer 300,
First - remove intake plenumSecond - cut each side of the egr pipes going into intake manifold about 3 inches from the point just outside the manifold.Third - crimp both pipes at the end as closed as possible, you will need to get a descent pair of pliers to do this. Fourth - apply CarGo ThermoSteel High-temp metal repair to both the crimp ends. You may have to apply multiple coats in order to seal it up properly.Fifth - Take egr cut ends to weld shop and have welded closed.
You can pick up the ThermoSteel stuff at advanced auto for not very much, make sure that it has the 2400F temp rating on it.
The best time to do this is over the weekend, I was able to get my car running within a day of doing so.
Good Luck!
JDMZ32
Car: 1991 Nissan 300ZX NA slicktop 5spd red
You don't need to remove the engine or transmission to delete the EGR.......
