feloniousmonk »
https://forums.nicoclub.com/feloniousmonk-u94651.html
Mon Feb 23, 2009 3:12 pm
1. Heat the badge with hair dryer. Don't need to melt paint off, just warm enough to soften the glue.2. Use dental floss or fishing line and saw your way though the adhesive backing.3. Use rubbing alcohol and terry cloth or micro-fiber towel to remove remaining residue. It's a solvent, but not strong enough to harm paint. It also evaporates very quickly.4. Polish and wax the area you used rubbing alcohol on. Chances are you've just added some scratches to the paint while wiping off the residue.
If you must use a screw driver to pry, tape the tip and areas of the car around the badge (as a precaution) with blue painter's tape and be very careful not to put direct contact on the car; use screw driver only to pull badge away from body, not to use it to leverage against the body.
All common sense, yes?
