nukeone »
https://forums.nicoclub.com/nukeone-u31978.html
Tue Aug 15, 2006 10:46 pm
Regarding "Woots" response, as far as I know, all 95's were OBDI while some of the 96's were OBDII. I have done the same swap, going from a '96 OBDII to a '95 OBDI. Once you swap the intakes, you eliminate the additional smog and sensor inputs, and you can then run the '95 OBDI ECU, not the '98 ECU.
