how to combat traction issue?
Fenvy
Car: 2005 350Z Base 6MT
ever since I tuned my car, I can't seem to keep the car on the road when I gun it hard. I can't WOT in 1st or 2nd gear without breaking traction.
I have nismo 1.5 lsd, 225 and 245 kumho ecsta MX tires
I am thinking about moving the 245 to the front and get some 17x10 and mount 275 ecsta MX tires in the rear.... what do ya'll think?
otterman
Shouldnt this be in the Tires, Wheels, Brakes and Suspension section?
ser2102
Car: 91 dead. 90 getting did
for straight line traction, you should get taller tires. wider will help but you will put more more to the ground because the taller tire will flex more. you might want to get a smaller rim and a taller tire.
Fenvy
are you the category nazi?
AJ1356
what i did to remedy that is some crazy tires, advan A048 295/30 but then again i drive my car once or twice a week. if you want mho go with something better than kumho. and if you have some 18s i have a set 265/35/18 for sale A048's ofcourse i am post whore i know
otterman
my recommendation is just get a KA. you wont have traction issues ever again lawl
nismofly
Car: 89 Nissan 240SX Hatch
you wont be any better off
ive come to the conclusion that you really will just have to deal with it, unless you want your car solely set up for drag racing and you run 15x9s with drag radials in the rear all the time
just drive normally in those gears
DrifterProdigy85
Car: 1989 Nissan 240sx (Zenki Onevia)
15x9 with 275/50-15 Nitto 555R Drag Radials would drive decent on the street and good at the track.
9240sx
Car: What i believe to be the cleanest s13 in the world.
SR20DET + RS*R-Apexi-Nismo-Trust-HKS= 100% pure love
Softer tires...Drag Radials will help tons..I like the BFgoodrich dragradials myself..
S13FASTBACKSR
Car: '92 Fastback SR powered
drop the pressure in the rear tires and possibly go with some better tires/ wider tires
Poor_S13_Driver
Car: S13
4-link the rear
otterman
I hear this is a pretty hot conversion in JDM land. Shoudln't have any traction issues then.
S13FASTBACKSR
otterman wrote:I hear this is a pretty hot conversion in JDM land.
this man is crazy....
otterman wrote:Shoudln't have any traction issues then.
but right
Fenvy
they have it for like suvs... but I think people are getting 5 to 10 mpg
what... 80% drive train loss?
S13FASTBACKSR
so loveless...whats the solution gonna be to your problem...have you decided?
Fenvy
I think the problem is partially me, I need to relearn how to drive with the car tuned. Before it was sluggish, rpm doesn't climb nearly as fast as it does now.
I plan to get 17x10 in the rear and either 255 or 275/40/17 but I haven't decided what tires to get.
When I go to tirerack.com their only 3 Extreme Performance Summer tires are Kumho ECSTA MX, which is rated higher than BFGoodrich g-Force T/A KD but shy of Yokohama ADVAN Neova AD07
So I automatically assumed that Kumho ECSTA MX will probably out perform a lot of daily driving tires in their list...
SRH Everyday
Car: 1995 Nissan 240sx SE
You should go with so Toyo T1S they have some of the best traction you will find another sugestion is get some adjustable shocks. Also don't be afraid to heat up your tire before you get on it.
AmoebAssassin
Car: 1991 Base fastback 5spd, black
Throttle control
You're approaching the limit of usable power in an S-chassis -- you're going to have to adapt a little to driving it.
Deftec
AmoebAssassin wrote:Throttle control
...Duy's 240 has 1000+horse on it and is still using the swing axle setup.
otterman
srpowered240sx
Car: 90 240sx-sr, 92 F-150, 00 bmw 323ci, 1991 s13 coupe, 99 F250 Dsl
bfg drag radials. with enough air in them they are good for everyday use. just be ready to burn through tires quick.
Fenvy
yeah I saw... some of these have 1/4 thread wear or already low thread wear tires...
I think I am going to work on it myself and upgrade to wider tires at the same time.
srpowered240sx
another question...what boost controller are you running?? maybe a controller that can do gear dependant boost. start at 10 or so, then have second boost 12, 3rd boost 14 and hit full boost in fourth.
Fenvy
which boost controller does that? I have blitz sbc-id
srpowered240sx
apexi avc for one just off the top of my head.
srpowered240sx
Drag racers may want to utilize the Gear based boost control function. Aside from the basic functions above, the AVC-R has a Start Duty Setting (allows the boost to momentarily overshoot according to gear).......from...
http://www.apexi-usa.com/produ...Num=1
DrIft Ready
Car: 1990 silvia built sr..
....waite!!! dont need traction..break it loos and slide it sideways..But if need..i say drop the pressure...make a world of diffence..in drifting to
