Johann »
https://forums.nicoclub.com/johann-u24065.html
Fri Mar 04, 2005 2:03 pm
Loosen the actuator and mark the position of the compressor and turbine housing in relation to each other.Loosen the bolts and turn the centre section to it's desired position. Fix turbine housing to centre section and clock the compressor housing until it is lined up the way it was for the actuator. You might have a few degree of play for the position of the compressor housing in relation to the actuator and wastegate flapper on the turbine but often this is very little.If the compressor housing doesn't line up the way you want you could look at the actuator bracket if it can be moved to the next bolts on the back of the compressor housing. Some actuator brackets mount against these bolts, other are mounted to the front of the housing. If you can't get a good position at all a new bracket is required.
You can even take the complete housings off if you want, just do it with care and don't force the fins on the wheels.
