assassin7420 wrote:Not to piss all over the parade, But thats WAY to low of a grit. Thats why the lights are still a little cloudy. If done correctly they should come out like this...
then up close looking into the housing.
Thats the OEM plastic that comes on our cars, NOT the glass that many people thought I had. My lights started out the same if not a little worse the the OP.
Man, this thread keeps coming back to life.Don't worry, no offense taken...even though this was way back when.
I have a question for you. What grits and procedure did you use to get your results.Did you use a power tool or just elbow grease?
As for the reason the lenses get yellow again, the coating that is applied from the factory wears off over time and us polishing it does a poor job of replacing the coating.
There are various companies out there that sell restoration kits and the difference between them is the quality and longevity of one coating against another.
There was a kit that was recently featured in Super Street (before they died). I'll go look it up and post it here.
I'll have to get some 1000 and up grit and do this again. It's time.
FlatBlackIan wrote: I polished the lights and then cleaned them using dawn dish soap, I then layed them out and sprayed them with three coats of Rustoleum crystal clear acrylic enamel... The enamel filled in all the imperfection and made the plastic way shinier and a lot smoother to the touch. Its been three months and they haven't yellowed a bit...
Ian, did you wet sand between each coat of acrylic enamel and how are the lights as of today? Can you post some updated pictures please?
Thanks,- Maximus
