90SXSE KA24ET DREAMS wrote:if cleaning everything doesn't work check timing/disturbor timing and also try adjusting your idle air control valve that's near the firewall if ur standing on the passanger side look to the far left of the intake and below there should be a screw and hole though a bracket... its not hard to find.. once you find it, start up car and adjust that screw..
no no no.. dont go adjusting the idle air control, fix the problem, if you half *** it and do that, you wil have problems later on down the road. rember if you ghetto **** up youll pay for it down the road. and cleaning the intake/plenum while its on the car, isnt a smart idea but do what you want.
