doridori23 »
https://forums.nicoclub.com/doridori23-u68081.html
Sat Jul 07, 2007 2:09 pm
If you can get the car to run on the ground just connect the water hoses to 5gal bucket having both under water with some Prestone flush/cleaner and run it on the bucket for a while then feed it fresh water from a garden hose.
IF you can not get the wiring harness out of the car or you dont want to do this then install it with your old rad and go to Walmart and get a backflushing kit from Prestone and various cleaners. Ghetto rig your rad with whatever you can and follow the directions. Drain afterwards put new rad in with straight water, run till warm, drain, and fill 50/50 coolant and a bottle of water wetter/ purple ice/ whatever additive you like best.
