loystock wrote:Be careful with Simple Green. Be sure you dilute it at least 50/50 with water. It's a strong degreaser and can cause the paint to become 'soft' and even peel off.
i think thats what happened with the 409. the clear coat is starting to flake off and got really hazy.
you guys really think i might have a chance at redoing the rims? i tried goo gone and got off a small patch that i tested it on. unfortunately, i dont want to be using that stuff, says on the warning label that its bad for rubber (tire) and its easy to just accidentally drip a little. i cant seem to find the simple green degreaser. the only one i found was the general purpose cleaner, and its as difficult to use as the 409 ive already used and messed up my rims with. takes lots of elbow grease and still doesnt clean 100%. my 2 back rims have pretty bad curb damage and i really want to just spend some time and sand it out and redo them. ive already damaged the clear paint on the set of rims by using 409 and 3m sponge.
i went to walmart today looking for simple green and found an aircraft stripper that i think might work for the removal of original paint. i dunno what these rims are made of, but its safe for aluminum and alloys, and says it degreases and removes all junk. the directions said something like spray, wait 15 mins, scrape, rinse. if it works as it says, then i can just sand the rims with either a metal brush or sand paper and repaint. shouldnt be too difficult.
