How to Clean Gasket off block?
jibroni69
Now i've got the head off and sent it off to the shop to be de-carbonized, pressure tested, checked for square, and resurfaced, How do i go about cleaning off the block so that i dont scrape crap into the cylinders yet leave a perfectly smooth surface?
corn322
Car: 1993 240sx
I guess if you did accidentaly scrape stuff off into the cylinders, you could bust out a shop-vac and vacuum it out.
basic
Car: computers, my car
i doubt you'll get a prefectly smooth surface without having it milled, and i doubt you want to pull the block to have that done. general steps to keep stuff out of the cylinders are stuffing them full of shop towels or something of the like.
Nismo1182
Car: Z06
Wire/Polishing wheel always works for me when im taking old gasket off (intake,exhaust,etc.)
It leaves the surfaces smooth and shinny.
CA18_Dreams
Car: cars, girls, cars, turbos, oh yeah and cars
please don't use a wire wheel... if you get the gasket off with a wire wheel it is posible to take of some of the metal also.... and that is a very bad thing when its your head on your block... even if it is ok on intake an such... i would recomend some carb cleaner or something like that and a razor blade... that is what i have always done...
basic
carb cleaner and razor blade are what i use as well. the only thing i ever use a wheel for are oil pan and valve cover.
Nathan
I have been known to use a wire brush, razor blade, and lots of cursing.
CA18_Dreams
nathan has a good point... you defenetly need a lot of cursing
Nismo1182
Car: Z06
I dont use a lot of pressure on the wheel. Just enough to get the gastket off and nothing else.
Spectre_240sx
Car: 1990 240sx SE
Call me crazy, but don't they make tools especially for scraping the old gasket off of components? I think they're called... Oh, wait, it's coming to me... Gasket scrapers, yeah, that's it! :D
Here's some linkage for your viewing pleasure:
http://www.thetoolwarehouse.net/shop/SK-6090.html
andrave
Car: 1989 Nissan 240SX Coupe
yeah napa has them for like 7 bucks.
CA18_Dreams
Some people don't like to spend money on something that they could just use a 10 cent razor blade for...
andrave
Well all a gasket scraper is, is like a giant flat screwdriver of sorts. I would suppose anything flat and capable of scraping would do just fine.
Spectre_240sx
Car: 1990 240sx SE
Well, that one was a kit of a few differen't types. 4 I believe. so 30 / 4 = 7.50, about the same price, but then again, if you don't need the different sizes and angles you could surely do with the 7 dollar scraper from napa.
The main advantage a scraper has over a razor blade is control. In some cases, a razor blade works just fine, but if the gasket is really stuck on, you will probalby have a hard time getting it off without a scraper. I've been there before and definately do not plan on repeating the situation :)
Btw... I noticed a certain devensive stance, so I would just like to make it clear that I was in no way trying to make a condescending post, though that may be how it came out.
