How to clean between the engine block and transmission?
Ryan Heo
Car: 1996 Infiniti I30
My 96' I30 which is 125k is hard to start in the morning again. The engine was cleaned by a mechanic a month ago after the transmission rebuilt. It cost almost $600. So I would like to clean the parts by myself, anyone know how to do it. Would you let me know?(There is no check engine light at all and the knock sensor was replaced 2 weeks ago.)
This is a labor description which I got last month.
CRANKS BUT WILL NOT START ------------ $192HAS SPARK AND INJECTOR PULSE. HAS GOOD FUEL PRESSURE. INSPECTED SPARK PLUGS AND FOUND PLUGS GAS FOULED.REPLACED SPARK PLUGS WIHT O/E STYLE.CARBON BUILD UP CAUSING HARD START WHEN COLD.NEEDS TO CLEAN MOUNTING SURFACE BETWEEN ENGINE AND TRANSMISSION. REROUTE GROUND CABLE TO THE STATER BOLT.
CLEAN MATING SURFACE BETWEEN TRANSMISSION AND ENGINE.INSTALLED GROUND CABLE TO THE STARTER BOLT. AFTER CLEANING VEHICLE NOW STARTS AND RUNS. -------------- $352
Thanks.
Modified by Ryan Heo at 1:35 AM 7/13/2007
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
I'm not really sure what to advise there.
I know a lot of people like products like Simple Green for cleaning grease.
Maybe some of the others can suggest some other good detergents for engine cleaning.
95prmax
Car: 1999 Nissan Maxima SE-L
ok i had this problem in the morning it wouldnt start for me it was the fuel pump it started going bad i bought a used walrbo 255 for 50 bucks used and it worked great til my car broke nothing ot do witht he fuelp pump....look into that
