BaliLover wrote: I currently have megan coilovers dropping the car to just above the top of the tires with 17x9 +20 235/40/17 rear, and 17x7.5 +32 215/405/17 front on the car.
The S13's stock rear sway bar is a piece of spaghetti, which is bad enough as it is, but with that kind of stagger, you're way out of balance front and rear. You should get some 17 x 9's for the front and if that doesn't help, pick up a hicas rear sway, or a whiteline, as many have suggested. I run 17 x 9 + 20 stretching 215/45's and my car is pretty neutral, with a tendency to understeer if I dive hard into corners. I still have the chintzy stock rear sway though. Anyone have a hicas they want to donate to me?!
anyway, good luck in your quest for sway bar domination.
