how to check timing on RB25????
Jo240sx
Car: 1998 Nissan 240sx
how to you check the timing on an RB25DET, then how do you adjust if its off +/- ........ all helps....... thanx
rb25drag
Car: 1990 Nissan 240SX 5.3 Chevy + 60mm turbo + blow threw carb.
I took an old plug wire I had laying around, Cut both ends off, Replaced them with straight end cremps, one side I plugged onto the plug, The other side I used a bolt Small 10mm I cut stuck it in the wire cremp as a conductor and wrapped some electric tape around the end to stick it in the coil so it would stay. Redneck way of making your own wire!!!!
That allows you to stick a timing light on the wire.
you use the CAS on the exhaust cam to adjust the timing.
Sorry I dont have any pics Hope that makes sense. If not Ill try to take pics and post them.
Joe
2 things
1) please search. please...this has been covered hundreds of times.
2) your signature image is too large, please read the rules here. thankshttp://forums.nicoclub.com/zerothread/203223
