how to check/set timing ?
s13s130
i looked on srswap and got confussed it talks about some spark plug wire hand crafted thingy cant i just use a timing light ?have i read correct do i warm it up them rev her past 3k 3times then leave it runing unplug the tps then check,and set dose it adjust on the cas like a distributer ? were are the marks ,on the crank pulley ? any help would be great i know she is not spot on it pulls uneven and backfires a bit the car motor combo is and 180sx black top in a 90s13 cpe and it has a hks bov greddy fmic and 3in down pipe and exhuast and no cat any help would be great layton ...............
SrS13
Car: 1990 Fastback, 1993 Convertible Coupe
If you wish to simply check your timing you dont need to unplug anything, you just your car reach operating Temperature and hook the timing gun to a loop there should be right behind your engine close to the last coil pack plug.
If you want to set it, you must drop your rpms to about 750 and unplug your TPS. point the gun towards your crank pulley Im pretty sure you'll see the marks.
Yes the CAS adjust timing like a distibutor, while pointing the light at the crank start moving the CAS up and down you will see the lines jump back and forth.
It should be set at the second mark from the driver's side that would be 15 degress BTDC.
hope this Helps
forgot to mention plug the TPS once you have set your timing then get your revolutions back to where you had them.
s13s130
some of the info out there realy makes things sound overly complicated ,thanks for the info i wasnt beleiving it was that hard to do or "so different" from other cars ":}
ItzGenX
Car: Smoke Purple 95' S14.5. Powered by the "Iron Man".
Yeah, I never understood the spark plug trick. I am not king of ghetto rigging stuff. I just looked through the FSM for the timing procedure a few weeks back to find out about the black loop on the coil pack harness.
