How to check oil pressure?
Deadrodent
Car: 1992 240sx hatchback
How exactly do you check for oil pressure? i understand i need the gauge but where exactly do you hook it up? my timing chain rattle is getting a little loud now but i also know my engine is pretty low on oil (my speedo sensor keeps popping out when i drive aggresively - and oil leaks out of it's little hole) Obviously the solution would be to fill her up with oil and remove the timing chain guides...but this is a question i've had for awhile so i might as well ask it now...thanks in advance!
BadMojo
Car: 2007 Mazdaspeed 3
You would hook it up to where the stock oil pressure sender is. Buy, borrow or DL a copy of the Factory Service Manual to find out what the specs for oil pressure are. You want to make sure you fix any problems before you end up with a useless hunk of metal under the hood.
InsanityInc
Uh, if the speed sensor keeps falling out and is leaking, that's gear oil, not engine oil. You should get that fixed too.
Deadrodent
hmmm...i might have some sort of oil leak elsewhere then....my oil is seriously low....man my car's going through it's time of the month right now. i have a tire that holds no air, either a bad alignment or blown tc rod bushings, car's low on oil, my engine's idle drops once i come to a stop but then fixes itself....i wonder what's next....gotta get this ish fixed...i really wish i hadn't got those reg violations.....aaarrrgh money!!!
