604-Allstar wrote:When testing the ignition coil which prongs should I be testing? I see on the coil there are 3 markings "IB", "G", and "+". Do you test IB and G?
also is there a range the the resistance should come between?
This is on two new Hitachi (OEM maker) coils; same result for both:
Between IB and G, I get about 1.5 kohms, whichever polarity (swapping leads).
Between G and +, I get open circuit with one polarity, 2.6 Megohms in the other polarity.
Between IB and +, same result as between G and +.
I expect that these numbers could vary quite a bit from good part to good part. I also expect that the coil
can fail in ways not covered by the factory manual clip in the post above, which seems to just cover the
case of a blown (shorted) power FET gate terminal.
Again, I recommend not to buy aftermarket coils from just whatever maker -- get OEM or Hitachi.
Are you scanning for codes? When I had a bad coil (from codes, and very rough engine), I swapped coils
to verify that the codes moved with the code.
