firstq »
https://forums.nicoclub.com/firstq-u958.html
Tue Oct 15, 2002 9:54 am
Just to add to your worries: I am currently doing my plenum job on 92Q. All 8 injectors were replaced 20K miles ago and #4 failed within 20K miles.
When I took all the others out, one of the injectors were showing a little bit higher that the other (13.9 as opposed to nice 12.5 or 12.6 for the others - but still within the safe range of 10-14 ohms).
I sent all to a local fuel injection bench cleaning shop - just to be sure. The one that was showing 13.9 jumped to 26.9 after the load test (at the fuel injection facility). Had I not done it, I would have just reassembled with a soon to go faulty injector - back to square zero.
So, in order to be really sure, you may want to send the injectors for bench cleaning and have them perform the coil test under load conditions for any anomalies. I paid $125 for the 7 injectors to be cleaned in Phoenix, AZ. The guy came out and picked and dropped the injectors within 24 hours from my work place.
Now when I put my injectors back in, I may just enjoy a little bit more piece of mind - still no guarantees.
Goodluck
