dustyk »
https://forums.nicoclub.com/dustyk-u13031.html
Fri Aug 26, 2005 7:29 pm
Ok, so I just installed a GT2871R, finally got it all fabbed up and I think the used Z32 maf that I got is shot. Im pretty sure that I have it wired correctly but I cant get the car to idle normally or even drive without running ridiculously lean all over the place. The ECU is a stock E5 SR20 ecu and Im running the new turbo with 550cc injectors and a Z32 maf and a SAFC. For some reason, even if I leave everything at 0, the car runs ridiculously lean (16.0-19.0) I actually ahve to add about 30% of fuel on the low throtle map to get the thing to run around 15.0 so that it idles without sputtering out. I try stepping on the gas but the SAFC barely shows any increase in airflow between idle and 2000rpm. Could I have a bad MAF, or is this more likely the wiring? I have the AFC set to 2 in 6 out like I should but the thing just wont run.
As a side note, everything worked perfectly fine up to 3 days ago when I still had the stock MAF, stock turbo, and 550s running with the SAFC
