How to check a relay by a ohm measure?
Ryan Heo
Car: 1996 Infiniti I30
Hi.My will go to long distance trip, so it is need to check all of the fuse and relay. I knew how to check the fuses but don't know to scan the relay by ohm measure including several function which can scan a battery, voltage, and diode for automoileWould you let me know how to do it?
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Nissan Relays do not go out very often. You cant check relays by doing a resistance test as basically relays are just switches. You need to feed them power and then see if the relay clicks on.
