How to change the headlight bulbs (S14 zenki)?
Mangudai
The fsm doesn't go into detail on this and because of this I managed to break the retainer clip on the right side. Do you pull the pull out or do you turn it clockwise or should you take the dust boot of first?
MAXIMUS Nismo
Car: 95 240sx SE
hold on, lemme find that for you.
EDIT - Found it. CLick the link in my sig that points to de-yellowing the headlights. I posted pictures that show how to remove the bulbs.
You don't have to take the headlights off but since you broke the retainer, you may want to.
I did the same thing the first time I tried to change the lights and broke the retainer on the driver side.
maj Andres
Car: Zenki, '95 Model, w/ S14SR20DET
Dont' believe that link provided above shows you how to remove the low beam bulb...
manafd
Car: 96' S14 Zenki
Soz if i'm bringing back a dead thread, but i have no clue as to how to take it out. The little tab that has the screw on it gets stuck on a little pillar which prevents me from removing the little ball bearing thing. a**
JustDriftMore
Car: 89+91 ku-pe
ill tell you how to replace a headlight bulb when you tell me how to put gas in my car, deal?
Black on Gold
Damn, people need directions to wipe their own a** these days. f*** its just a headlight bulb.
Dazzla
Its really easy. The retainer is a pain in the a** to get off but its not impossible.
manafd
Car: 96' S14 Zenki
Well i don't want to BREAK mine like the op and the guy helping him out did, i'm asking for help because i'd like to careful and not damage my car.
Clearly i'm retarded right?
nightsauce
Car: 1991 Nissan 240SX S13 hatch RIP
1992 Nissan 240S S13 hatch :D
Black on Gold wrote:Damn, people need directions to wipe their own a** these days. f*** its just a headlight bulb.
numbnuts240
1974 Datsun Fairlady-Z 250GT
2011 Ford Focus
2010 Mazda 3
jeebus christmas. unscrew the cover on the back, unplug the harness from the bulb. pull off the rubber boot. there are 2 metal tabs on each side of the bulb, push in (towards the front of the car), then push towards the bulb. once you do both sides the bulb will pull right out. reverse for installation.
DMan II-40
Car: 1995 240SX SE
numbnuts240 wrote:jeebus christmas. unscrew the cover on the back, unplug the harness from the bulb. pull off the rubber boot. there are 2 metal tabs on each side of the bulb, push in (towards the front of the car), then push towards the bulb. once you do both sides the bulb will pull right out. reverse for installation.
You should add pictures for a more detailed write-up.
JustDriftMore wrote:ill tell you how to replace a headlight bulb when you tell me how to put gas in my car, deal?
Win
numbnuts240
2011 Ford Focus
2010 Mazda 3
it's bad enough that the procedure had to be typed up, there's no way in hell that i'm going to do a step-by-step with pictures.
