How to change Steering rack bushings?
runnerb240
Hello,
I need to replace my steering rack bushings, and I was wondering if anyone knows what is involved with doing that? Is it a simple task? Do I need to take apart my steering rack to do it?
Thanks!
working4aS13
Car: Base 95 240SX
FSM ST-12 gives you an idea of what is involved.
Four bolts that attach the rack to the motor crossmember; then you should be able to take the cover/brackets on the top side; remove the old bushings; install the new; re-install the covers/brackets; torque the bolts down 65-80 ft/lbs; get your 240 aligned.
positron1
Car: Project: 1993 Nissan 240SX Coupe SR
Daily: 2010 Honda Civic Coupe
Viola... S13 Steering Rack Bushing Install zerothread?id=213930 It's easy, an excellent "cut your teeth" experience for the begginer shadetree mechanic. This is one of the first things I did when I first started working on my car.
dickie
Car: Killer Turtle
thanks for repping your article, positronone!
