how to change starter on 240sx 1995
newpuy
how to change starter on 240sx 95, I try to take the starter out but i can't I did lower the transimission but i still can't get it out. in the book said I should remove the transimission lipstick but I can't get it out either please me help my car is stuck on my drive way now pleaseeee helpppppppppppppif you can tell me step by step or if you have picture that would help me alot I already bought rebuilt starter ( USA industrial ) is it ok rebuilt ?? thank you very much
Chingon
Car: 1991 and 1992 hatchbacks
what's wrong, stuck on something? there are 2 main bolts holding it to the housing. After that, there's nothing but connections (one held by a nut) and I think to others w/snap connections.
gabossie
Car: Your mom
Did you get the bolt on top? It's a ***** to get to, usually requires more than a few extensions and a contortionist.
scottsnissan
Car: 1995 240 sx se
i jus changed mine yesterday.U have a auto or five speed .I know on a five speed the top bolt is fairly easy.Jus get a Short socket on it .U dont have much room but after a couple turns u can get u hand on it.Also its eaiser to do the top first so that is no bind on the bolt.
1995 240 sx se
newpuy
it's automatic I can't get into the top bolt. I can lost the bottom bolt easy but the top bolt I very have a hard time
