How to change spark plugs?
stanzaboi
Car: s13 coupe
On elast subject for you guys. I've seen this done plenty of times but have never done it myself. Also, it's been a while since I've actually done anything to my car myself.How exactly do you change change out the spark plugs? I'm going to be taking off the the valve cover to clean it so I figured I'd change ou the plugs and wires. Thanks.
ILikeMy240sx
Car: SR Power
1. Pull on the spark plug until it comes off.2. Using a spark plug socket and an extension (it has a rubber insert inside so it grabs on the the spark plug when you pull on it) unscrew the spark plug out of its place3. Check the gap of your new SP and make sure its with in specs.4. Torque it down properly
http://www.zeroyon.com/TheSite/techservice.html-bunch of FSMs that should help you.
mmatl16
Car: 240sx rb20 swap
ill help before u get flamed......
go to the nearest auto part storetell them what kind of motor u havethey'll give you a list of optional spark plugsbuy some nice ones (its always nice to upgrade even the smallest stuff)take ur valve cover offget a 3/4 inch sockettake out the old onesinsert the new ones
easy as that
own3d
Car: 95 FD3S
NGK's have always served me well. but yeah its pretty simple, just pull the spark plug wires out(might take some wiggling) unscrew it, sparkplugs are 5/8's btw NOT 3/4. then start the new ones in without the ratchet, just socket and extension then tighten them down with the ratchet. put the plug wires back on and boom your done. so much easier than these damn hyundai's, you have to take the freakin inatake manifold off to replace the back plugs and wires on some of the v6's
ILikeMy240sx
Car: SR Power
taking off the intake manifold to replace spark plugs..... wtf lol
own3d
Car: 95 FD3S
ILikeMy240sx wrote:taking off the intake manifold to replace spark plugs..... wtf lol
yeah working on hyundai's sucks, they also decided to put the oil filter about an inch away from the exhaust manifolds on every single engine they make so when you have to change the oil on a warmed up one you burn the piss out of your hand I HATE HYUNDAI
GT Ranma
Car: 1995 Nissan 240SX
3000GT you need to take off the Intake Manifold to change 3 of the 6 sparkplugs ^^;;
Yeah, changing the Sparkplugs on the KA is quite easy u.u; I never did it on my RB, but on my SR I put racing sparkplugs in, thats just the name for 'more expensive' :p And the danm thing started knocking on cold days when I started it up. I was also using crappy American gas, once I switched back to Japan's (high octain) gas that went away ^^;;;
4felix20
Car: Emerald Blue S14
mmatl16 wrote:take ur valve cover off
own3d
Car: 95 FD3S
4felix20 wrote:!?
lol, i didnt even notice that, i think you just directed the flamers away from him and into yourself, good job
mmatl16
my bad guys lol
i was thinking about my coil pack cover for my RB20.and i dont know why i said 3/4
i think he got the general idea though
stanzaboi
Car: s13 coupe
Thanks guys for all the info. I'll go ahead and change them out tonight.
ILikeMy240sx
Car: SR Power
wow... did you happen to notice that no one here flamed? hey Greg, you should be proud of us
If this happened elsewhere like (____) i dont even know how they would react
crzycav86
Car: 93 Nissan 240SX KAT
And another tip:
Don't forget to put antisieze on the threads of the sparkplugs. You should buy that when you get your new spark plugs.
And on a side note, when you take your valve cover off, make sure that when you're putting it back on, tighten the bolts in the right order. The fsm will tell you how.
