Difficulty: Very easy
Time: under 10min
Parts Needed
2 PCV valve Nissan part # 11810-EY00A
2 Rubber gasket Nissan part# 11812-6N200
Tools needed
23mm deep socket or 23mm wrench
extension
ratchet
original package with part numbers from nissan
to locate the pcv, remove engine cover and follow the two vacuum hose from the center of the engine which will lead to the pcv's. One leads to the left of engine and the other to the right side. It is blue in color, you may have to wipe the dirt to see the blue.
pcv drivers side.
pcv passenger side.
install gasket on pcv
Remove the hose using pliers.
Remove old pcv using ratchet or socket. I used deep socket with 1/2" drive and extension.
install new pcv.
HAND TIGHTEN. USE RATCHET JUST TO TIGHT A FEW mm's.
DO NOT OVER TIGHTEN THE VALVE AS IT IS MADE OF PLASTIC.
I only use premium gas and I was shocked to find both the valves clogged!! Very easy DIY highly recommend to do this.
