How to change out the stock alternator in a 97 maxima
quisp2112
Car: Maxima 1997
Does anyone know how to change out the core of a stock 97 maxima alternator?? Mine isn't putting out enough amperage and I need to upgrade but don't want to pay for the labor
-thanks
Graberhieny
Car: 1995 Nissan Maxima
This is going to get a very general write up of how I changed mine out.
1. Remove the passenger side tire.2. Remove the fans off the radiator. You will need to do this in order to make working room for the remove of the alternator.3. Remove the splash guards on the passenger side.4. Remove the serpentine belt. 5. Remove the 4 large bolts that are holding the a/c compressor in place.(Be care full with the lines, since you are nt going to disconnect them. You just want to be able to move the compressor around, so that the alternator can be dropped down. 6. Remove the bolts that are holding the alternator in and remove the wires from it. 7 Replace the new one and then put everything back on in reverse.
This is just of the top of my head. It should be able to get you where you need. It is not a hard job at all. I got mine done in 2 hrs, and I usually get sid tracked when working on my car.
Hope Helps.
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
Don't forget to disconnect the battery before working on the alternator, too.
coolhand
Car: 1995 Nissan Maxima SE
1. Remove the passenger side tire.2. Remove the splash guards on the passenger side.3. Remove the serpentine belt. 4. Remove the 4 large bolts that are holding the a/c compressor in place.(Be care full with the lines, since you are nt going to disconnect them. You just want to be able to move the compressor around, so that the alternator can be dropped down. 5. Remove the bolts that are holding the alternator in and remove the wires from it. 6. Replace the new one and then put everything back on in reverse.
Note: the fans do not need to be removed to get at the altenator.lossen the belt tensioner just enough to get the belt off. if you go to far, the adjustment nut can lock up and will not allow you to adjust to tighten the belt after the altenator is installed.
