how to change oil and tire rotate light
Forum for the unique Murano, and official home of Nissan Murano Club!
drfting240sx
Car: 1992 240sx and 04 murano
hey im in the marine corp and im at school my fiance is got the murano but had the tires roated and the oil changed but the shop is dumb and cant reset it any help?
Virgis
Car: Nissan Murano-2004
This is from 2003 Murano owner's manual.Maintenance itemsYou can set the engine oil and the tire rotationinterval.And the tire pressure will appear on the screen(if the tire pressure system is equipped).To display the setting of the maintenance inter-val, select the “Engine Oil” or “Tire Rotation” keyusing the joystick and push the “ENTER” button.To set the maintenance interval, select the“Maintenance Schedule” key by using the joy-stick and push the joystick to right or left.To reset the maintenance interval, select the“RESET” key using the joystick and push the“ENTER” button.To display the MAINTENANCE INFORMATION,automatically when setting trip distance isreached, select the “Display Maintenance Noti-fication” key and push the “ENTER” button.
Timmbo
Car: 2013 Infiniti JX35 AWD
2013 Nissan Maxima Sport Pkg
Virgis wrote:This is from 2003 Murano owner's manual.Maintenance itemsYou can set the engine oil and the tire rotationinterval.And the tire pressure will appear on the screen(if the tire pressure system is equipped).To display the setting of the maintenance inter-val, select the “Engine Oil” or “Tire Rotation” keyusing the joystick and push the “ENTER” button.To set the maintenance interval, select the“Maintenance Schedule” key by using the joy-stick and push the joystick to right or left.To reset the maintenance interval, select the“RESET” key using the joystick and push the“ENTER” button.To display the MAINTENANCE INFORMATION,automatically when setting trip distance isreached, select the “Display Maintenance Noti-fication” key and push the “ENTER” button.
Well spoken!
drfting240sx
thanks guys it helped out alot it suked being 600 iles away and no car to physicly see the problem. thanks again
Return to “Murano Forum”
