Juelze »
https://forums.nicoclub.com/juelze-u44994.html
Sun Sep 09, 2007 8:57 am
Well I finally did this today. Not a complete PITA. The worst part was putting everything back together but I'll explain more on that later.
Here are the steps.
1. There are 8 screws holding the glove box compartment to the dash. 4 of the screws are on the bottom and are only accessible when the glove box is closed. The other 4 are on the top of the glove box compartment are only accessible when the glove box is opened.
2. Once all 8 screws are removed, you will be able to pull out the whole glove box assembly, but only pull it out part way as there is an electrical connection on top of the glove box which I'm assuming is for the glove box light. You might be thinking "Duh!" but I've never seen that light come on and thought it was an additional option. Anyway, just press down on the white part to unlatch this connection and you can remove the glove box completely.
3. Now to remove the in-cabin air cleaner. It's on the bottom middle of the dash right against the firewall. Removing it according to the service manual didn't make sense to me. "Compress the filter downward..." Huh? The plastic molding that holds the paper element isn't compressible, it's rather sturdy. There is no tab for the filter on the top, but there is a tab on the bottom of the filter, that doesn't help me. Ugh. I finally figured out what they mean by "Compress the filter downward." Imagine a deck of playing cards, now if you apply equal pressure to the top and bottom of the deck, nothing happens. However, if you apply downward pressure on the top of the deck at an angle, what happens? The deck bows or bends (i.e. compression). In this case, the the plastic the the air filter is attached will bow slightly to the passenger side when you apply downward pressure at a slight angle. You probably won't be able to visibly see the plastic bowing, but that is what they mean by "Compress the filter downward." Anyway, once you use that compressing/bowing action, pull the top part of the filter out.
4. Once you have the top part of the filter removed, just lift up the bottom of the filter to unlock it from the tab holder. Voila, the filter is out. (note: be mindful of a foam covered assembly that somewhat obstructs your view of the in-cabin air filter, it will get in the way of removing the filter unless you filter towards the firewall).
5. Putting the filter back in is a cinch, you just have to hold the paper element (accordian like) down and push it in being both mindful of the tab, and using some slight "compressing" technique.
6. Now for the fun part, Go grab the glove box assembly and slide it back in halfway. Attach the glove box light connector (only goes on way way) until it clicks into place. Shove the glove box in the rest of the way and put the 8 screws back in. Simple enough right? Wrong. This was the hardest part for me because you essentially have to keep pressure on the glove box so you can line up the screw holes so you can screw it back together. I normally expect this when taking things apart. The part that irritated me is that there are these little metal spacers between the plastic of the glove box and the actual screw holes that move around. I had to use a small nail to move them back into position and quickly get a screw started so they didn't fall back down.
If anyone has any questions, please let me know. Also, if my glove box is supposed to be illuminated (not sure if it was standard or optional) I hope to god I don't have to remove the glove box again. While not difficult, it's something I'd only like to do once a year.
