Actually FiBS, I used bokingwen's procedure to install mine. so the instruction does work.bokingwen wrote:Here is the link to the instruction on how to install HID on the EX. I belive I have the same HID as ramprun. I bought my HID from Ebay been using it for almost a year and they are great. The only thing is I chosed the 3000k instead of the 5000k, if I have to replace my exiting one I will get the 5000K because I think bright light!
zerothread?id=387954
I think 5000K is the best compromise for looks and brightness.bokingwen wrote:Here is the link to the instruction on how to install HID on the EX. I belive I have the same HID as ramprun. I bought my HID from Ebay been using it for almost a year and they are great. The only thing is I chosed the 3000k instead of the 5000k, if I have to replace my exiting one I will get the 5000K because I think bright light!
bokingwen, do you have 35w or 55w kit? i have 55w kit without relay wires and my car has trouble starting the engine and only one bulb would lit up. if i turned off the auto headlight, started the car first then turned on the headlight, it works perfectly but it a pia to remember to turn off and on the headlight. i want to hear about your experience with the kit. anything strange after installation.
I have the 35w kit with a relay and I have zero problem with it. It works fine with the auto on off. I bought the relay with the kit however I didn't do the acutal ordering, my buddy ordered the HID for me. I think he brought the the Kit from ebay along with the relay.ramprun wrote:
it is always worth it to add the relay for the extra layer of protection.bokingwen wrote:
The main reason I spend the extra $ on the relay is I don't want the after market HID F up the electrical on the EX. Since the EX have so many tech and electrical stuff in it (I have the tech package). If you ask me I think it is worth to spend the extra $ on the relay.
I agree! I think 35W HID kit is ok to plug directly to OEM headlight harness without problem. I have problem with the RELAY harness itself than the actual HID kit.ybe4094 wrote:That's fine. But for exactly this reason the car has the 15A fuse built in. It's OK to include an external relay while connecting the HID lights. The reason I made my post is to show that the relay is redundant from electrical engineering point of view. It will simply overcomplicate the circuitry by introducing extra components (the relay itself and connectors), which always have some probability to fail. Thus, the total reliability of the circuit will be reduced. Just my 2 electrical engineering cents
Modified by ybe4094 at 9:42 PM 12/11/2009
