how to change brake fluid?
gizeye
if its not too complicated to change the brake, can someone tell me how please?
onosqv
Car: '92 240sx Vert
You can change brake fluid a number of ways. If you don't know how to bleed your brakes (just getting the old nasty fluid out), you can search for that on here or Google - already covered pretty well. Easiest w/ 2 people. If you can't have another person help you, there are DIY brake bleeding pumps as well as speed bleeders.
Way I usually do it:
1) Put car up on jack stands & remove wheels.
2) Siphon out most of the brake fluid from the bmc (there's lil $10 hand pumps you can get from the automotive store)
3) Refill part way with new fluid
4) Began brake bleed/flush using your favorite method.
5) bleed each caliper until good fluid comes out (while continuing to refill the cylinder as it starts to become empty)
And Done! Easy
