How to change accessory relay
dustovshio
I got no power to cc, stereo, wipers. Read online accessory relay or ignition switch to blame. Anyone know how to change or is there a write up or should I just pay my mechanic buddy to do it 40 bucks an hr ?
robomatic12
Car: 1990 300ZX TT
If there is no power, the first thing to do would be to check the fuse panel for blown fuses. The relay and ignition switch fail much less often than a blown fuse. Mind you, there is normally a reason for a blown fuse. Such as a hackjob of a radio install.
Pull off the cover for the fuse panel located at the drivers footwell, look for those specific item's fuse and check the condition of it.
dustovshio
the fuses are not burned out, but my mechanic said they are not getting power
