how to can i raise my strut/springs higher
q45ondubs
Car: 1998 q45
I want to put 22 inch rims on my car but it seems that the spring comes down to low right above the tires i have 20inch rims right now with no rub no problems at all but right now with the dubs thers very little space in beteween the tire and the springs.is ther any way to raise that spring or strut help out experts...
the_sauce
Car: Enormous Land Yacht
Ummm..... Not going to happen.... Without spending a LOT of money to have customs front struts built.
But honestly... 22's on a y33?? Why bro??
peter_rabbit
Car: 2003 m45 white pearl, '99 mustang gt vert
Actually there are knuckles that you can put in between your springs that would raise it about an inch. You would install thlem with a 4 way lug wrench. The only problem with those is that sometime you'll get a bouncy feel going over bumps and afte awhile, they will start to squeak. You should be able to find them at any local Autoparts store.
07sportm35
Car: 2007 Infiniti M35 Sport
You'd be better of with coil spacers all the way around. That way it won't effect ride quality.
They can be had for $10 a pair. You remove the springs and place the spacers underneath them.
The rears would be super easy to do. Use tie-wraps to secure them to the spring.
Check out this link...
http://forums.maxima.org/6th-g....html
the_sauce
He is not talking about raising the spring itself, but the springs seat that is part of the shock itself. Custom shocks will have to be built... No other way. The y33 is MUCH different than the y50.
q45ondubs
Car: 1998 q45
peter_rabbit wrote:Actually there are knuckles that you can put in between your springs that would raise it about an inch. You would install thlem with a 4 way lug wrench. The only problem with those is that sometime you'll get a bouncy feel going over bumps and afte awhile, they will start to squeak. You should be able to find them at any local Autoparts store.
i thought about that also but that will raise the car how ever i dont think it will actually raise the spring because i need clearance between the spring and the tire....what do you think
q45ondubs
Car: 1998 q45
07sportm35 wrote:You'd be better of with coil spacers all the way around. That way it won't effect ride quality.
thats cool i like how you did that but i think the spring is still going to hang over the tire ..or will it give me more space between the tire and the spring...because the spring hangs over the tire and i need the bottom of the spring to raise....let me know what you think
the_sauce
Why were my posts ignored?? They dont understand what you are trying to do....
Other way to do this is to get some coilovers from Japan and adjust as needed.
But honestly, you are going to be spending a minimum $2000 to make this happen whichever way you do it.
q45ondubs
Car: 1998 q45
the_sauce wrote:Why were my posts ignored?? They dont understand what you are trying to do....
realy now how about some high performance struts that come with smaller springs...and ther has to be a way cheaper than 2k...what do you think...but you seem what im saying right..i want more clearance from the tire and the spring that comes down right on top of the tire...But honestly, you are going to be spending a minimum $2000 to make this happen whichever way you do it.
the_sauce
Quoting failure... forgiven.
Coilovers for the y33 run from $2400 and up(highperformance struts with smaller springs). I had a y33 and had coilovers, and a loooot of other suspension work. I am trying to tell you that what you want to do will cost you ALOT!! It sucks, you can thank Nissan for their amazing front strut design...
q45ondubs
Car: 1998 q45
wow thats krazy thats i little to much now how about these other guys on this forum that have 22inch rims did they have to spend that much or is ther a cheaper way to do these things..
the_sauce wrote:Quoting failure... forgiven.
BadQ45t
Car: '21 Nissan Leaf SL Plus (wife's car)
'05 Nissan X-Terra S 4x4
'97 Infiniti Q45t SOLD! Miss the old girl
'84 Nissan 300ZX (Original Owner)
'16 Mercedes Benz S550e V8 Power & 35 MPG
Dude, just chill with your 20's...do something that will really help the handling of your car like KYB SR Specials and some Espelir or Tein lowering springs. 20's are plenty big.
Why did you post this in the M35/45 forum?
