rico05 »
https://forums.nicoclub.com/rico05-u8176.html
Tue Dec 09, 2008 5:46 pm
DALAZ_68:Well, I would use 1 of the smaller ones for oil pressure, 1 for temp and block 1 off to use with my write up. The GReddy one you posted as 2 large ports for cooler lines and 2 smaller for gauges.
Fancy_Footwork:A trans cooler for a M/T would require an external pump. Not really a necessary addition for the power levels I am running.
hbpignosePA:And yes, more oil is needed. Some simple volume calculations from the 8th grade (volume of a cylinder), plus filling the cooler with fluid will get you a ball park in the new liquid volume. My CA runs ~3.3q factory, and I run 4.5q now.
