How to: Black out rear Badges PICS
Pathfinder3.5
Car: 2002 Nissan Pathfinder LE Gold
So I decided to black out the rear decals on my 2002 Pathfinder LE. I didn't want to paint them Black permanently just incase there was a mistake during painting. I also didn't want to remove the badges from my Truck. So I used Plasti-Dip. Worked amazing!
Things needed:
-Lots of Newspaper
-Green Painters Tape
-Your color choice of Plasti-Dip (White, Black and some neon colours)
-Time
-Preferably Dawn soap (Due to the de-greasing agent)
Start off by cleaning the surface around the Badges. Clean in between the letters very good. Use some warm water and a soap with a degreasing agent. Wipe it dry with a micro-fiber cloth. Tape a square off around the badges. Plasti-dip wont stick on paint so taping off each letter is not necessary.
It should look something like this:
Original:
Once your all taped off you can go ahead and start off with your first coat. Your first coat should only be light, The second and third will be the heavy coats. Let it dry 10-15 Mins for the first and second coat and a good 20-25 for the third heavy coat.
Once it has dried it will peel off the paint like this, It will not come off the Badge itself. If you messed up you can take something sharp and get under the coating on the badge itself and peel it off.
If you choose to do all of the badges tape them off like you did all the others. On the "Pathfinder" Badge you may notice some flaking chrome coating in between the smaller openings in the letters. Try and remove most of it and clean the dirt out the best you can.
I was really impressed with the outcome. The finish is a nice smooth rubber-like coating. It made all of the Badges stick out much more than the regular chrome. It definitely will look different on some colors. On Silver, White or the light Gold color it would look amazing.
Finished product:
With the Nissan badge painted:
fueler
Car: 2 Nissan's
2 BMW's
The way it peeled off the paint, im wondering how long this mod gonna last. Good write up
Pathfinder3.5
fueler wrote:The way it peeled off the paint, im wondering how long this mod gonna last. Good write up
Just to see I tried to get it off the LE...It wasn't budging without some force. I see people paint their rims with this stuff so it is quite durable. And Thanks!
m0nkeyprince
Car: 1998 Qx4
just a suggestion, maybe try sanding the chrome a little bit with like a 1500 grit or 2000 grit sandpaper before hand
Pathy415
Car: 2002 Pathfinder LE 4WD
Looks good. While looking through the pics I noticed the rear wiper arm could use some of that plasti-dip. I wonder if it will work on that?
01silvapathy
Car: 2001 Pathfinder LE 3.5
Plastidip is pretty stout stuff, I painted my rockers with it to see what it would look like and it held up well until I scraped some rocks on it then it looked bad so I just took it off and sprayed it with bedliner.
Here is a video of plastidipped rockers with a pressure washer nozzle, stuff held up great
[youtube]http://www.youtube.com/watch?v=t0tkWqzaJDY[/youtube]
donald
Car: 2001 Infiniti QX4 (RIP, 2011)
2010 Pathfinder LE
hey! I know someone that did the same thing!
calling esy to the white courtesy phone!
Innovazn
Car: Yellow 1998 Nissan R34 Skyline RB25DET 5 MT - Current
White 2012 Nissan Altima Coupe 3.5SR 6MT - Salvage (T-Boned at left turn)
White 2002 Nissan Pathfinder LE - SOLD (blew the engine)
so... the paint does not stick to the car body and comes off?!
01silvapathy
Yes it comes off if you want it to come off........ as shown by all the pics and videos above.
SBK03SE
Car: 03 Pathy SE RWD Fully Loaded
Y'know, that black plastic/rubber liner right under the LE under the trunk door, mine is a bright GREY and I tried waxing it, after some sun it was grey again. Would Plasti-dip work on it? And I'm thinking of doing this to my front end, to do or not to do? It's all scratched up anyways...and if I don't like it I can peel it off right?
xxectoxx
Car: 2001 nissan pathfinder LE
this is awesome i want to try this for my car but i am a little nervous. thanks for posting this!
SBK03SE
@xxectoxx DO IT! Plasti-Dip is amazing!
link to my threadplasti-dip-ideas-black-out-roof-wheels- ... l#p6136020
