Beancooker »
https://forums.nicoclub.com/beancooker-u42602.html
Fri Dec 01, 2006 10:12 pm
This process works for 5th and 5.5th gens. 4th gens won't properly "save" the advancement.
You can advance your timing to 17* BTDC. You HAVE TO run supreme unleaded after this, otherwise you may have spark knock.
You will only gain better throttle response and a fraction of accelleration.
Advancing your timing with Nissan’s CONSULT II tool.For those of you with dealerships like mine (the tech may need a little help)
On CONSULT II main menu screen choose “ENGINE”Check out any codes that are stored, then clear codesPress “WORK SUPPORT”Press “TARGET IGN TIMING”Press “UP” x2 for 2 degrees, correction which you should be able to seePress “UPDATE”Press “BACK”On the “WORK SUPPORT” screen find “IDLE LEARN“
Perform this, since your idle will have changed.
