How to adjust e-brake tension on a spec v?
1gr8v
Car: 2002 sentra se-r spec v
I have an 02 spec v that has absolutely no tension on the e-brake cable. The cable is not broken i just need to know how to adjust it. Thanks!
ABNRML4U
Car: Nissan B13
I found you something that may help you:http://www.b15sentra.net/forum...62522
I just Google.com and gave me some Info.
RED_DET
Vendor
2011 Infiniti G37x
Chevrolet Corvette Z06
You have to remove the center console to reach the adjustment.
spec_v03
Car: 1991 Nissan Sentra SE-R
no need to remove center console i just did mine. take a 10mm deep well socket on a 6" extension. spread the rubber flaps around the ebrake, the nut that you see in there adjusts it. get the socket on and let the ebrake down fully. tighten the nut, move handle up a click, and repeat until the handle is hard to pull. should be tight to pull after 6-8 clicks.
