How To Add Transmission Fluid - Manual transmission - 98 240 SX
tonypatthou
I don't know how to check my transmission fluid. I don't know how to add transmission fluid to the transmission.Someone mentioned that one must unscrew the shifter, and pour the fluid in a hole. Help.
Tony
jab11185
Car: 1992 Nissan 240sx
tonypatthou wrote:Someone mentioned that one must unscrew the shifter, and pour the fluid in a hole.
yep....that's what i did....it's just 4 bolts holding a round metal plate down and a snap ring holding the shifter in place
tonypatthou
how can you tell if the fluid is low. Does a 240 have some kind of dip stick.how can I avoid overfilling the transmission.
sanioll
Car: Nissan 240SX SE
Toyota Camry
tonypatthou wrote:I don't know how to check my transmission fluid. I don't know how to add transmission fluid to the transmission.Someone mentioned that one must unscrew the shifter, and pour the fluid in a hole. Help.
Tony
Hello noob!!
please use the search button on the upper and right side of screen. You will find that i did a FULL write up on how to change your transmission fluid. just search for "transmission fluid"
also search for FSM, service manual and read it. to check it though, you open the side bolt and check it wit your fingers. just see the manual.
