audtatious »
https://forums.nicoclub.com/audtatious-u2438.html
Tue Feb 20, 2007 4:43 am
If your amp handles speaker-level inputs, then you can simply disconnect the factory sub and redirect that into your inputs (realize this configuration would already have a filtered output). If not, you will need a hi-lo converter (line level converter) and tap off the sub or the rear speakers.
Alternatively, you can use a converter like the PAC AOEM-nis2 (with OEM-1) bundle. This will install at the back of the radio and will give you 2 pairs of RCA outputs and a amp-remote line.
